BACKGROUND:
In my 89 4Runner with a freshly rebuilt 22RE engine, I noted a leak soon after I had the transmission rebuilt and switched the engine to Pennzoil Platinum and the transmission to Redline. The leak started slow and had me confused about the origin for quite a while. I finally convinced myself it was engine oil coming from the rear main seal, but it turned out to be the head gasket. I finally visited a mechanic when I noticed a 1/2 quart drop on the dipstick in a short period of time.
The diagnosis was that the block and head had been machined with a surface that was very rough and the copper shim had been installed dry rather than with a special sealent. Unfortunately, the block and head had been machined to the point that the copper shim was required to avoid clearance issues.
OBSERVATION:
I'm sure that one of the reasons that I had to run premium fuel to get quality horespower (by advancing the timing) was partially related to having higher compression from the "excessive" machine work.
QUESTION:
The mechanic said that in his experience, head gaskets installed with copper shims are more prone to developing leaks as a result of the normal heat cycles. If it would have been possible he would have preferred to leave the copper shim out. I'm sure the leak would have developed at some point with conventional, but the PP seemed to be the straw that broke the camels back. In the mechanics opinion, the seal didn't have a chance given the surface conditions and the shim being dry. He block sanded the surfaces and used the proper sealent so I'm considering staying away from synthetics (the engine has no real need for them) on the outside chance that it would be more likely to find a leak path in the future. How crazy am I?
OBSERVATION:
QUESTION:
