OE spec is 29/32; something like that for normal, marginally loaded applications, more for sustained high speed or heavy loading. Ill look on my drive to work and tell you for sure later.
That said, for highway driving, Ive generally pumped them up to 30/34ish, or even 32/36 (around the fully loaded spec pressure). The problem is that the car will ride like a buckboard if you have lousy roads - forget understeer/oversteer. Youll feel a lot translating through.
I'd suggest trying first to lower your felta front to rear - set the rears to 33 or 34, ad see how it responds. If that doesnt work, Id not go lower than 30 PSI for the rears, so start adding to the front.
I had heard from one person that 33 all around works well, but Ive never tried it.
JMH
