Petition online
Quote:
Question:
Oil for Volkswagen TDI Diesel Engines
I have a new Volkswagen TDI diesel and the warranty says it must use only VW oil, which is synthetic (made by Castrol). I've used Mobil 1 in all my cars for 20 years and would like to stick with Mobil 1, Help.
-- John Gaylord, Corvallis, OR
Answer:
Unfortunately we do not currently have an oil in the United States for this particular application which requires VW 505.01.
Quote:
Mobil 1 ESP Formula 5W-30 specifically formulated for the latest VW TDI specification 507.00/504.00 and is recommended for VW 502.00,503.00, 503.01, 505.00, 506.00 and 505.01, 506.01 (except Unit-injector RS/V10-TDI and 3/4 cylinder diesel Engines without Longlife-Service) Also meets BMW longlife 04 and Mercedes Benz 229.31/229.51 specifications. ACEA C2/C3, API SL/SM.
Avlube claims ESP meets 505.01, but it's not on the PDS. Mobil only makes 5w-40 S in europe which is specifically designed for 505.01.
*I'm behind the times here....so 506.01 is the latest VW spec? Does that mean using an oil that meets 506.01 can also be used for 505.01 applications?
Quote:
Question:
Answer:
