Last night while I couldn't sleep I was thinking about maybe trying to make a transmission fluid exchanger that would work as well as those machines they use in a shop. I was thinking I could take a 4" peice of pipe a few feet long, and put some kind of piston in the middle that would slide up and down. I could then fill it with clean fluid, hook it up to my transmission, and have the dirty fluid push on the piston which would inject clean fluid out the other side. I'd need some kind of bypass valve so it could circulate as normal after the fluid runs out.
Has anybody ever tried such a thing? Think it would work? What kind of oil pressure does a transmission normally operate at?
