The M1 has better filter specs compared to the relabeled Wix (NAPA Gold). Same price go with the M1. Also, M1 describes their media as synthetic blend, not full synthetic.
From the M1 website:
Quote:
The filter box says that Mobil 1 Extended Performance Oil Filters contain a synthetic fiber blend filter element. Are these related to the synthetic components found in Mobil 1 synthetic motor oils?
No. Most conventional oil filters use a filter medium that is made of cellulose – typically wood fiber – and polyester fibers. Mobil 1 Extended Performance Oil Filters combines a mixture of synthetic micro fibers and natural fibers to produce the most efficient oil filter on the market. The synthetic components of Mobil 1 motor oil are chemically synthesized liquids.
The synthetic fibers in Mobil 1 Extended Performance Oil Filters yield the following key benefits:
A much more efficient filter, removing more particles per pass through the filter than conventional filter media.
Less resistance to oil flow, reducing the potential for the filter to restrict the flow of oil to your engine.
A larger surface area to trap more contaminant particles, allowing the longer service intervals
