Hi! I am new to this forum so bear with me. I think i can help with any questions that have risen about WMO Waste motor oil as a diesel fuel. I have been in aviation / heavy equip. /light equip., as a technician, mechanic , designer and engineer, but most of my knowledge has come from me just doing experiments in the garage!
so here goes: Can you burn wmo in a diesel? Short answer yes! Long answer, it need to be filtered and centrifuged and /or distilled (boil the alcohol and or water out) slightly to work well. You can run it with out doing this as i have but it works much better this way. It still seems harder to start but runs ok, Smokey, but ok. I have also burned trans fluid, gear oil, hyd oil, WVO, JET A, B (jp4), kerosene in percentages and combinations of 10% to 90% with no ill effects on the engines, other than different color smoke, and slightly lower or higher power out put. I will say this from my experiments. Running waste jet fuel, (or kerosene) requires that you add some lubrication to the mix...usually trans fluid or, the best is 2 stoke oil, 128:1 or higher is fine. This is for the fuel system mostly. The idea that waste oil burning causes an increase in crankcase oil volume is mostly, false. Can oil or another alt diesel fuel bypass the rings into the case? Yes. Not often and not much but, Truth is, it does happen.
Next: veggie oil needs to be heated! I am in MN and if u don’t heat it all u get is a nice wax sculpture. It burns well and smells good, but you need to filter it, and if you want bio diesel than you need to do some other things as well, still worthwhile though.
Gasoline: use at your own risk/ yes I have used it, in fact when I "garage refine" some of my fuels i use gasoline or E-85, it works well...but a high level of caution should be exercised when using any amount above 10%, don't be fooled by the fact gasoline has less energy (btu's) by volume than diesel, WVO WMO, etc.. Its not it’s output, its HOW it burns! , Gasoline tends to EXPLODE haphazardly under compression ignition! This is why I use e-85..As alcohol (85%) resists compression ignition and alleviates this problem to an extent when mixed with the other alt.fuels..plus its cheaper. Still 10% MAX is my , and my melted engines, recommendation.
If this helps let me know!
