Again, good post, and yes I dreamed of an edit button too, my typing is lame!!
On with the discussion.....
Quote:
The increased pressure is not to narrow up the footprint - that isn't the way it works except at high pressure / low load situations.
The purpose of the increased pressure is to increase the pressure within the footprint
This is a bit of a contradiction. Increasing psi to only increase pressure within the footprint will not occur, you need to reduce the surface area of contact, or increase weight. Tire pressure alone will not do this. Let's say we have a perfectly balanced car, a 3,000lb car with 200 sq inches of tire/road contace area at 35psi, this puts you with 750lbs of load per 50 sq inches of contact. With no reduction of surface area, running 40psi is still 3,000lbs, 750lbs per 50 sq inches. All we've done is reduce the tire's ability to conform to the terrain.
If we reduce surface area, as in the edges of the tires are raised, we've increased lbs per sq inch, increasing contact pressure, but now with a tire providing less friction/traction since it is now less pliable. A tire running lower psi will be much more pliable and provide better traction.
Quote:
Besides, the pressure recommendation is based on the idea that you are using the same size tire - not comparing different sizes.
Not necessarrily in all cases. Ford uses a standardized psi recommendation, as do other manufacturers I'm sure, so I do see it quite viable including different sizes :
Windstar 15/16"= 35psi
Freestar 16/17"= 35psi
Freestyle 17/18"= 35psi
Focus 15/16" = 35psi
1/2 ton F-Series 16/17/18/20" = 35psi
Super Duty's non-dually 16/17/18/20= 55fr/70rr psi
Quote:
First, you were using the same rims? The LT235/85R16 should be using a 6 1/2" rim and the LT265/75R16 should be using a 7 1/2" rim, so to get the equivalent situation you need to be using different rims.
The truck came with Firestone Steeltex AT's, 265/75-16 10 plys, on the factory 16x7 wheel you saw in the pic. I see no issue using a 7" wide wheel with both sizes, you can get either tire from the factory with this same size wheel. IMO it's vital to keep as many variables the same between tires when comparing, it eliminates factors that may effect performance.
Quote:
Second, to get the equivalent loading situation, you needed to use less pressure - 34 / 43.
I still would have more surface area and less pressure, less traction. The only way to match the 235's traction would be from adding weight to match the lbs per sq inch.
Quote:
And this doesn't take into account that you didn't do back to back tests.
This actualy was back to back, same day, same conditions. I am great friends with the manager and assist manager at the local big chain tire shop, we have done many comparisons between brands over the years, different vehicles. When we test these tires, I get priority for change-overs, and we keep the miles low and do not abuse them, they do get sold. Other shops have even done the same with us, so we've actually covered a pretty big volume of tires just being a bunch of guys curious about which tire keeps our kids the safest in the winter.
I may even be considered by Nokian for R&D in real world applications (my vehicles/fleet) for central BC, I am very excited about this, as you can probly tell, heheh.
Quote:
Tire traction testing is very difficult because of the variability. It takes many runs with the traction vehicle to get reliable data. And while I have no doubt about your experience, I have seen quite different results from highly controlled tests - enough to make me know that doing tire traction tests as little as a few hours apart is fruitless.
I agree, and dissagree. The more data, reliable data, the better, absolutely. But considering I'm just a Canuck in the deep frozen north, heheh, I don't have the means so I/we work with what is available. It is very easy to run 3-4 different sets of tires over an 8 hour period, as long as the weather is cooold and the conditions don't change. Sometimes the resuls vary so much you don't need to record the results, sometimes you need a stopwatch, or the tape. Either way, I absolutely agree a controlled enviroment with as much data is ideal, but I don't agree if you can't access this format of data collection it is fruitless.
Quote:
But I get the sense that you believe the inflation pressure equals the footprint pressure. Not true. Even though this seems intuitively true, it isn't.
Actually, this it what I sense you believed.
Quote:
The purpose of the increased pressure is to increase the pressure within the footprint.
Isn't that what you've stated here, you're increasing psi with the belief you're increasing footprint pressure.
Quote:
Pickup trucks have a unique problem when it comes to tire loading. The pressure needed to support the load when the truck is fully loaded - this is the placard value - is quite a bit higher than the equivalent situation when the bed is empty.
Cars have this problem, but 1) they are rarely used fully loaded, and 2) The problem is much less severe than with a pickup.
This is why trucks, like my crew cab for example, are so ideal to find the traction limitations of tires, compounds, widths, psi, etc. It is sooooo easy to get to the limits, and adjust accordingly to maximize the available traction. I've had cars that would of been useless for test pigs, just by design they found traction so well. Where you would take a sports car, or mini-van, throw it in a controlled enviroment for data collection, and need the recorded data to decipher the results, a huge Super Duty with a light rear end throws them out at you.
Quote:
Bottom line - I think the pressure increase is a valid recommendation, but it gets a little dicey when we start talking unloaded pickup trucks.
I'll share a story of a trip with you, it pretty much nips the raising psi theory in the bud, IMO anyway.
It was Jan/06, My family and I flew down to Vancouver BC to spend a week with my sister and her kids. The airport car rentals were dishing out 4wd SUV's at huge prices, I took a Freestar with 235/60-16 Goodyear Integrity, junky/old design/technology, cheap.
Anyways, Budget thought I was insane with the warnings of snowfall on the lower mainland, I don't care. I drive 6 months a year in gross winter conditions, I almost sickly enjoy driving in Vancouver when it snows, everyone panicking, I love it!
We get to our hotel, and decide to drive over to my sister's after we check in, well the snow hits, and it's coming down hard. In Vancouver they don't get feet of snow, it' a greasy, wet, layer of slop, slippery as snot. Well we pile in the van, I stop at a 7-11 to get some juice and snacks for the kids if we get trapped somewhere in a lineup of smashed cars, and I also get myself a tire guage.
We cut through some odd roads, avoiding the main flows of grief-stricken Vancouverites that have no clue how to drive in snow, and I head to the worst hill in the area, it's the shortest way to get to my sisters from the Executive hotel on north road, we're going up Galiardy Way on Burnaby mountain. I figured this would be a clean shot, no one would dare drive this way, man was I wrong.
By this time there's buses stalled out, other vans, cars, and lunatics in suv's running 4wd to the floor, bouncing off curbs, flailing wildly. I lock the tranny on 2nd for better tractability, and slooowly crawl around the majority of stranded people, until the slope degree increases. The JunkYears provide nothing on this thin layer of greasy cheese. A few more attempts, nada.
No one is close to me, the suvs are way up the hill flailing all over, I get out and drop the psi. All the tires were set at 35psi, I put them to 26psi....... sidewalls got a nice pliable bulge, they don't look rock hard anymore, let's see what happens......
....... I roll back a few feet so I'm not starting on a polished patch, 2nd gear, I crawl up and away, spinning slightly through the polished spots, and I actually have enough traction I'm gaining speed too. I ascend the hill so well I catch the 4wd suv's smashing the curb and sliding everywhere, I stay back and let the unexperienced ruin their rims and sidewalls. We eventually get to my sister's, I drop off the kids and wife, and I'm sent out for for food/supplies if the city ends up in total chaos for a few days.
I do contribute my experience in winter conditions a major factor, but I couldn't make the hill at 35psi where 26psi did, that cannot be ignored. It is not data from a controlled test enviroment, but it is years of data contributed from experience, experimentation, and the desire to maximize all available traction to keep my family the safest. I'm all for just as much psi you need for a full footprint and no more to keep it pliable.
Hey, this place would really be boring if we all agreed on everything, right?
Cheers,
Not-so-CrazyMike
