Hello everyone,
I have a 2006 Toyota Tundra Double-Cab Limited 4WD with Limited Slip Differential. At around 5,000 miles, I replaced the lubricant in the Limited Slip Differential, Transfer Case, and Front Differential with Amsoil Severe Gear 75W-90.
At around 6-7000 miles, I began to notice my passenger side front tire was wearing too much on the outer edge. At the same time, I experienced what *felt* like a "scrubbing/rumble/vibration", when accelerating from a stop with the steering wheel turned. It was as though the truck was in 4WD mode on dry pavement, only I was not in 4WD mode.
So I took it in for an alignment...The alignment guy said my alignment was way out. I told him about the vibration and he told me it's quite possible it was due to the alignment being out, hence the "scrubbing" sensation. I thought initially I had the problem solved. But I soon realized that was not the case.
The problem is still happening - It happens when I begin at a dead stop, with the steering wheel turned, and step on the gas. The sensation only happens for about a second or less, and doesn't happen once I am above 5-10 mph.
If I accelerated from a dead stop with the steering wheel straight ahead, the sensation doesn't happen.
I tried going to an empty parking lot and doing lots of tight figure-8 turns, at both 5 mph and 10 mph, but cannot get the sound to happen.
Am I experiencing LSD clutch chatter? Assuming the problem IS LSD chatter, is this how that problem would normally manifest itself? If I go ahead and add the LSD additive, and that turns out NOT to be the problem, will the fact that I used the LSD additive cause any problems, even if it was unneeded?
