Cross Reference list for all manufacturers?
Atlanta, Jawga
I was wondering if there is a complete listing for cross referencing oil filters across the list of brands? For example If I have a Wix xxxxx which Purolator/Fram/NAPA would fit? My googling has come up with limited results.
Check the manufacturer websites; at least 3 that I know of have cross reference functions. Put in the a competitor number and you'll get their number.
try Wix, Puroil, Fram
There are probably others.
Alrighty then....
PF53
PF47
Wix 51086
Wix 33225
Only # I could find for this Purolater L28812
Wix 51160
But it sure would be nice to have a complete cross reference listing for when you to pick up parts. Most auto parts never cover all the filters applicable from different manufacturers.
PF53(Lube)
Amsoil-EAO33 Purolator(Pureone)-(P)L10241
Bosch-3330 Quaker State-QS3614
Fram-PH3614 STP-S3614
K&N-HP-1002 Supertech-ST3614
Mobil 1-M1-102 WIX-51215
Motorcraft-FL267 Carquest-84023
Napa-(2)1215 Champ-PH2835
Pennzoil-PZ21
PF47(Lube)
Amsoil-EAO29 Purolator(Pureone)-(P)L10111
Bosch-3331 Quaker State-QS3387A
Fram-PH3387A STP-S3387A
K&N-HP-1001 Supertech-ST3387A
Mobil 1-M1-101 WIX-51040
Motorcraft-FL321 Carquest-85040
Napa-(2)1040 Champ-PH47
Pennzoil-PZ9
51086(Lube)
Amsoil-EAO25 Purolator(Pureone)-(P)L20049
Bosch-3322 Quaker State-QS30
Fram-PH30 STP-S8873
K&N-HP-1011 Supertech-ST5
Mobil 1-M1-111 WIX-51069
Motorcraft-FL10 Carquest-84099
Napa-(2)1069 Champ-PH454
Pennzoil-PZ3
33225(Fuel)
AC Delco-TP1239 Fram-PS3808
Baldwin-BF791 Luber-Finer-LFF3808
Carquest-86225 Hastings-GF197
Donaldson-P550677 Napa-3225
Fleetguard-FF5059 Purolator-F55101
Racor-B32013 WIX-33225
L28812(Lube)
AC Delco-PF2139 Carquest-85160
Champ-P834 Quaker State-QS5320
Fram-CH5320 STP-S5320
K&N-HP-7006 Napa-1160
WIX-51160
51160(Lube)
Same as the Purolator L28812
If there are any other brands that you want that I haven't listed, let me know and I can add them to the list.
Go, Champ! Go!! You can take over looking up all those numbers ..every day.
Oh ...did you forget any over size options for him??
PLEASE!! Keep up the good work.
Here's a place to go when you've got some oddball filter number and want to know what its spec's/construction is. Something strange that you may see on Ebay. You can't typically use this outfit's numbers with anyone else's ..but it will give you an idea of replacement costs for the oddball setup you're considering. After you've seen enough filters, you can identify the gasket/thread and figure out what you're dealing with in many instances.
FilterMart
No I didnt list any oversized versions, but they are really easy to get too, if there are any oversized numbers needed, I can get them.
Quote:
----, now I know why you're the "Champ" Urock!
I have to ask where and how did you find all these?
If I told you, I'd have to kill you. lol
I just have access to most filter manufacturer's numbers, so I don't have to go from site to site to get them. I find what your filter fits, I look it up by application, and bingo! Thats what saves the most time. But back to work...
PF46(Lube)
Amsoil-AEO32 Bosch-3332
Champ-PH44 Carquest-85042
Fram-PH3506 K&N-HP-1007
Mobil 1-M1-107 Motorcraft-FL2030
Napa-(2)1042 Pennzoil-PZ48
Purolator-(P)L14006 Quaker State-QS14006
STP-S3506 Supertech-ST3506
WIX-51042
GF652(Fuel)
Duetsch-FF3504 Baldwin-BF853
Carquest-86481 Luber-Finer-G481
Donaldson-P550209 Fleetguard-FF5026
Fram-G3727 Motorcraft-FG851
Napa-3481 Purolator-F33144
Quaker State-QSG3727 WIX-33481
