Quote:
Quote:
The M5 engine likes ester and pao oils the best,
Did your M5 whisper this into your ear?
Hammer
It shouted at me from a fistfull of UOA's
Hammer
Quote:
Hammer
Quote:
So you tested all Ester or PAO based oils against all group-III oils?
Hammer
Quote:
Hammer
No, I just passed on my observations from a stack of UOA's on my engine with different oils. The ester and PAO's performed collectively best.
The S62 is a good news - bad news kind of engine. The good news is that the engine has a big sump and an oil-water heat exchanger. The bad news is that the engine has low tension rings, a double-row drive chain for the cams, it pressurizes the oil to 1450psi for the VANOS and it produces so much carbon you'd think it was burning coal. It's tough on oil and it shows if you do the analysis.
Quote:
http://www.bmwz8.us/pdf/zz-Engine_Oil_Specs.pdf
With BMW switching the rec'd oil from 10W60 to 5W30 in 3/00 does that mean most M5 owners aren't using the 10W60 anymore?
Would RLI 5W40 be a good choice for this engine?
Quote:
I'm actually a bit more curious about the US-spec S50B32 that came in the E36 M3 and Z-roadster/coupe. My sister has one and I've been wondering if it's ok to run 5W40 in it. And what length OCI to run.
Quote:
The S50b32 never existed in the US, FYI. Model year '95 got the S50b30, and '96-'99 (thru 2000 or '01 for the MZ3) ran the S52b32.
After watching issues with these engines over time - they like thick oil, with short-ish OCI's. VANOS rattles and failures are normally caused by 2 main conditions - too long of OCI (oil dependent, obviously), and VANOS solenoid failure.
I have a good bit of experience with these engines, and regardless of UOA's, these engines prefer thicker oil. The 10W-60 is a great oil, if you're willing to pay for it. I've ran Castrol GTX 20W-50 in many with never an issue, and recently switched to Rotella Syn 5W-40. Have a friend with a '03 turbo'd 325 (M50b25) that engineers and designs turbo kits for these cars who has also been recently recommending the Rotella Syn for these cars. In a 20 minute session at Road Atlanta neither of us have any lifter OR VANOS noise issues, which cannot be said for most of the E36 guys running factory-spec oil.
