Car will be driven in Rochester, NY 6 miles each way. Will be garaged overnight, but not during the day.
My brother recently transferred to Rochester and thought about selling the car as it will be rather ill-suited for short commutes in snowy Rochester. But the car suffered much of its depreciation in the last few years while he's had it, so he decided not to take the hit.
My concern in the winter is that even after a 6 mile drive, the oil will still probably not be flowing optimally if he stays with a 40wt. The car will not be used at all for longer trips.
My initial thought is a top quality 0W-30 oil might be best, again, assuming the car will be limited to these short commutes. Such an oil will on average be closer to the correct viscosity than a 5W-40, for instance.
I see Amsoil has changed their 0W-30, I don't see where Redline makes a 0W-30...are there any other options? Are the Esso XD oils available in Rochester?
Or do you think my 0W-30 thoughts are out in left field? He would be aware that his HTHS will be in the mid-high 3s vs 4.5+, so he'd need to be careful with this 400hp beast.
Thanks,
Tim
Thanks,
Tim
