The boat has a Johnson 70hp 3 cyl 2 stroke with oil injection. There appears to be some water in the gas tank. I can't see any, or get any out when I siphon the tank - but when running I get water in the carb bowls.
I am looking for a fuel drier (isopropyl?) that will work with a 2 stroke. I am afraid of using regular fuel drier because I don't want to counteract the oil with alcohol.
Is this a non-issue? What do you recommend.
