2002 Dodge Dakota QC 4x4
EQUIPMENT MAKE: Dodge
EQUIPMENT MODEL: 4.7L V-8
FUEL TYPE: Gasoline (Unleaded)
OIL LAB: Oil Analyzers (left 4 columns)/DysonAnalysis (right most column)
Overall, I thought the wear numbers looked pretty good based on the miles on the oil, but Terry thinks there is plenty of room for improvement. I'm disappointed in Mobil 1 EP as others have mentioned as well. I'm not certain, but I think that was the second consecutive time I used Mobil 1 EP.
code:
Oil Brand Mopar Mobil1 Mobil1 Mobil 1 Mobil1 EP
Oil Weight 5w30 5w30 5w30 5w30 5w30
Oil Filter Mopar Mobil 1 Mobil 1 Mobil 1 Mobil 1
Sample Date 10/4/02 2/15/03 6/26/03 3/08/04 9/15/07
Miles Oil 1201 4140 5300 7737 13,362
Miles Eng 1201 5509 10800 18537 62,918
Iron 18 22 22 31 36
Chromium 0 4 3 6 5
Lead 0 2 1 0 0
Copper 10 6 7 20 11
Tin 1 0 0 0 0
Aluminum 3 8 6 11 8
Nickel 0 0 0 4 2
Silver 0 0 0 0 0
Silicon 16 21 20 8 16
Boron 34 138 234 242 72
Sodium 1 19 15 25 25
Magnesium 0 40 44 19 83
Calcium 1124 3038 2859 3025 2195
Barium 0 0 0 0 0
Phosph. 887 1055 1022 975 741
Zinc 1098 1108 1156 1140 929
Moly. 0 73 107 147 98
Titanium 0 0 0 0 0
Vanadium 0 0 0 0 0
Potassium 0 0 0 0 0
Fuel 1.1
VIS 40C - - - - 69.9
VIS 100C NA 8.9 10.13 10.41 11.0
TAN - - - - 4.37
FLASH - - - - 360
Oxid 6.7 4.0 8.0 6.7 37
Nitr 5.7 3.0 5.0 5.7 19
KF - - - - 350
TBN 6.9 7.37 7.89 6.9 2.0
Soot N/A N/A N/A N/A 0
Water 0.05 0 0 0 -
Sulfate - - - - 34
Note there is a gap in the history during a period of time when I didn't have oil analaysis done. The oil was in use for approximately 1 year, although it obviously should have been replaced well before then based on the analysis. The air filter was replaced about the same time as the last oil change. Driving is 60/40 highway/city.
According to this report, a TBN less than 3.0 is considered too low. The oxidation and nitration levels are very high.
I will not be using Mobil 1 EP again after the next oil change, and will be changing a number of things based on Terry's recommendations.
