A relative sent this to me and asked my expert advice.
A few points may be correct however some of it smells of chain forwarded
Hope this is not a
Quote:
Gas Saving TipsI don't know what you guys are paying for gasoline....Here in California weare also paying higher, up to $3.50 per gallon. But my line of work is in petroleum for about 31 years now, so here are some tricks to get more ofyour money's worth for every gallon. Here at the Kinder Morgan Pipeline
where I work in San Jose, CA we deliver about 4 million gallons in a 24-hour
period thru the pipeline. One day is diesel the next day is jet fuel, and
gasoline, regular and premium grades. We have 34-storage tanks here with a
total capacity of 16,800,000 gallons.
1. Only buy or fill up your car or truck in the early morning when the
ground temperature is still cold. Remember that all service stations have
their storage tanks buried below ground. The colder the ground the more
dense the gasoline, when it gets warmer gasoline expands, so buying in the
afternoon or in the evening....your gallon is not exactly a gallon. In the
petroleum business, the specific gravity and the temperature of the
gasoline, diesel and jet fuel, ethanol and other petroleum products plays an
important role. A 1-degree rise in temperature is a big deal for this
business. But the service stations do not have temperature compensation at
the pumps.
2. When you're filling up do not squeeze the trigger of the nozzle to a
fast mode. If you look you will see that the trigger has three (3) stages: >
low, middle, and high. In slow mode you should be pumping on low speed,
thereby minimizing the vapors that are created while you are pumping. All
hoses at the pump have a vapor return. If you are pumping on the fast rate,
some; of the liquid that goes to your tank becomes vapor. Those vapors are
being sucked up and back into the underground storage tank so you're getting
less worth for your money.
3. One of the most important tips is to fill up when your gas tank is
HALF FULL or HALF EMPTY. The reason for this is, the more gas you have in
your tank the less air occupying its empty space. Gasoline evaporates faster
than you can imagine. Gasoline storage tanks have an internal floating roof.
This roof serves as zero clearance between the gas and the atmosphere, so it
minimizes the evaporation. Unlike service stations, here where I work every
truck that we load is temperature compensated so that every gallon is
actually the exact amount.
4. Another reminder. If there is a gasoline truck pumping into the
storage tanks when you stop to buy gas, DO NOT fill up--most likely the
gasoline is being stirred up as the gas is being delivered, and you might
pick up some of the dirt that normally settles on the bottom.
Hope this will help you get the most value for your money.
Hope this is not a
