JHZR2
Staff member
I have a question regarding exceeding sidewall pressure ratings.
A lot of hypermiler folks set their tire pressures at well above door and sidewall ratings. 50 PSI or a p-metric tire is not uncommon, and Ive seen mention of 70 psi. The thinking is that a tire will not pop until at least 250 psi, and so there is still plenty of safety margin.
So, besides higher shock loads to the vehicle body and potentially higher centerline wear, what are the issues regarding increasing tire pressure above sidewall numbers? What else can happen? Apparently a lot of folks are doing this without issue, and Id certainly assume that this is better than driving with too low a pressure...
However Id appreciate any technical insight as to what the pros and cons are with doing this from a tire quality, longevity and performance (and any other technical tire) standpoints.
Thanks!
JMH
Thanks!
JMH
