Quote:
I see that the Wix 51515 has a maximum flow rate of 7-9 GPM.
So does the Porsche and VW filters that the OEM number xref's to
All these filters have a bypass valve ..so there should be no "worries" about breaching the media.
The common hydraulic filters are rated for 16 gallons ..but you'll be getting a different mount and the availability will be more limited.
Part Number: 51551
UPC Number: 765809515512
Principal Application: Various Hydraulic Applications (10 Micron)
All Applications
Style: Spin-On Hydraulic Filter
Service: Hydraulic
Type: Full Flow
Media: Paper
Height: 5.209
Outer Diameter Top: 3.663
Outer Diameter Bottom: Closed
Thread Size: 1-12
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=5/13
Burst Pressure-PSI: 380
Max Flow Rate: 12-16 GPM
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.729 2.415 0.255
If that's the way you want to go, the hit up northerntool and search "hydraulic filter". They're cheap, have 3/4 NPT ports and a built in 25lb bypass valve. There is a passenger car xref for this thread/gasket too. It too sports a higher flow rate and may be easier to find in the auto parts chains. It has its own bypass and ADBV.
Part Number: 51228
UPC Number: 765809512283
Principal Application: Various Jaguar Models (97-05), Ford Thunderbird (02-03), Lincoln LS (00-02)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.685
Outer Diameter Top: 3.150
Thread Size: 1-12
By-Pass Valve Setting-PSI: 16
Anti-Drain Back Valve: Yes
Max Flow Rate: 12-15
Gasket Diameters
Attached 2.800 2.441 0.240
On your current mount, do you have pressure taps that will allow you to fit a gauge? If so, I'd get a cheap (salvage, off of ebay - there are plenty) 0-30 psi gauge and mount it upstream of the filter. That will tell you if you're at the PSID required to open the bypass valve.
Now this is opinion ..that is I don't "know" ..but my take is that hydraulic filters tend to be finer than their like sized automotive counterparts. They probably have the same holding capacity, but are typically employed in a cleaner environment that doesn't have to cope with the routine introduction of combustion byproducts. I can't resolve the flow rating difference beyond the difference between the "reasoned" matter of a hydraulic fluid being a 10 or maybe a low 20 weight. Even 10W motor oil isn't considered a 20 weight since it's doesn't have a HTHS of 2.6 (IIRC) even though it's in the 20 weight range
