Just busted another wheel cover on the Fusion
I hit a pothole that I couldn't see, and it felt like the entire car exploded. The tire is fine, but a large chunk of the wheel cover is missing and the metal rim underneath is a little scuffed, and maybe the slightest bit bent, but I cannot tell. If it is a little bent, should I just leave it, or maybe try to suggest it back into shape with a hammer? I'm replacing the tires before too long, so should I have the tire place fix it then? I've never had a bent rim before. And when I say bent, I really do mean like so slight I'm not sure... the bead area is very thick steel.
