1995 BMW E36 M3
In the Middle of doing replacing my Front Wheel Bearings (146K on the originals - on this car the Front's come with a new Hub also)
Not paying close attention, I momentarily stuck the new Hub/Bearing (OEM) on backwards (just by hand, so no force), quickly realized it and pulled it off. The inner race (outside inner since it was backwards) stuck until I pulled it off. In the process, some of the factory grease came off on my glove. Not much, but some... (it's a clearish looking grease) I was thinking it might be a good idea to put some more back in there before I mount it permantly. So I picked up some Mobil 1 Synthetic Bearing Grease at Autozone....
My question, do you think it's ok to mix the Greases? I really don't want to take the Bearing all apart and clean up all the old stuff if possible....I'd rather just spread some of the colorful M1 stuff in there....
I know the Syth Oils mix fine with Dino stuff, I assume there would be no bad things by mixing the greases? (for all we know the stock grease is a Synth)
Thoughts?
Thanks!!
Thoughts?
Thanks!!
