Some of you are WAY overthinking this, and some just need to take a chill pill. First of all I'm talking about a Jeep with an iron engine designed in the 60s. (4.0L inline 6) The Cherokee body it rides in was originally designed for either a 2.5L 4 cylinder or a 2.8L V6, and the radiator frontal area was designed for these engines.
Later on, AMC shoved the big old inline 6 in there with the same radiator. Thus, the reason Jeep Cherokees are notorious for overheating, even with a good cooling system. In addition to that, my Jeep has never run at stat temperature unless it's still warming up, not even in the middle of winter on an open highway.
Originally Posted By: Craig in Canada
In more extreme conditions (stop and go, idling, extremely hot weather, racing, long grades, towing) the system may rise above thermostat temperature because it now actually needs to do some work to control temperatures. These, and only these, temperatures will be lowered by changes to coolant or system sizing. Even then, they should never go lower than your thermostat control temperature otherwise it will close.
This is exactly the problem. The last few days I have been driving with only water in my system as part of the radiator flush. The engine has never run cooler. My stat is 195 degrees and the engine normally runs at 210, both below the boiling point of plain water. Now, add a 16lb pressure cap, 25% antifreeze, and a bottle of water wetter and it's NOT going to boil.
As for corrosion protection, again 25% antifreeze + water wetter should completely eliminate that concern. On top of that, converted car engines in boats seem to run on pure lake water just fine. And again, this is an old iron jeep. Not some fancy new aluminum thing with strange coolant.
Originally Posted By: Kestas
If the engineers thought that pure water (with corrosion inhibitors) would be best for use in very hot climates, they would say so in the owners manual... but they don't.
Since when do engineers write owners manuals? The manuals are written by accountants and lawyers with the EPA breathing down their back - the useful life of your vehicle isn't one of their concerns. If everybody followed the owners manual then this board would be completely pointless, wouldn't it? Owners manuals also tell you never to use fuel or oil additives, and often give ridiculously long OCIs or bad advice on oil weight.
