Originally Posted By: Mr_Joe
It does run, but barely. It's making knocking noises & leaking oil out the exhaust. I have a no frill mower shop nearby that I've used before, maybe I'll let them give it an eval.
With oil coming out of the muffler, it sounds to me like the crankcase is full of gas due to a carb problem (overflowing), this is NOT unusual, I have seen it a thousand times! To start off with, the carb needs to have the needle & seat replaced, the float replaced (a common failure!), and the oil changed. When it is started back up it will smoke for a while but it will clear itself out in a few minutes. This simple and inexpensive repair may just solve the problem.
