I know what Port Fuel Injection is, I know what Central Fuel Injection is, but what the heck is Sequential Fuel Injection?
Thanks, DEWFPO
Thanks, DEWFPO
The fuel rail supplies fuel to the injectors, not the other way around!! On Bosch systems, there is one injector for each cylinder. The injectors squirt fuel into the intake port, usually on top of the valve. I think they all squirt at once because of a limitation of the older microprocessors used back when the first MPI systems came out, in the late 60's.quote:
Originally posted by Ferb:
When a TPI system fires, it really only has one or two injectors. These injectors fire into the injector-rail itself, which injects the fuel at the intake valve runner.
Some allege that the "puddling" that you assert causes build up ...actually is used as a valve cleaning characteristic. That is, after warm up, the cool fuel hits the back of the hot valve and keeps it free of deposits. I'm not arguing with you ..just relaying the alleged advantage of "puddling".quote:
or have been sitting for almost two engine revolutions (too much buildup).
I think K-jet is CIS and squirts all the time. L and LH squirt once every two rpm's, unless its on a v-8, then it alternates cylinder banks once per RPM. Some other engines, i.e. v-6 and straight six may also use this scheme. The D-jet on my buddy's 914 alternates banks via an extra set of points beneath the ignition point plate in the distributor. (Old!!)quote:
Originally posted by cryptokid:
it depends upon which bosch injection system you are refering to. cis (continous injection system) they all squirt at once. k-jet and d-jet i believe fire in banks of 2, a hybrid so to speak. l-jet i am not sure of. motronic fires individile injectirs, and of course the bosch diesel fuel injection fires individually into the head or prechambers.
Oh no. I definately agree that at a "proper" firing time, the fuel can provide a necessary cleansing element. It also allows for more complete atomization of the fuel. Thats the biggest benefit to SFI-- complete control over how much the fuel is atomized.quote:
