Since certain gun- and automotive-oil makers say that their oil becomes attached to the metal surface, I wonder if an oil's protective properties still exist after being wiped away with a clean cloth? I.E., does a visible sheen of oil need to exist?
One particular oil I have in mind is Redline, which I recently chose after doing a salt-spray test on a few nails to see which synthetic automotive oil (Redline, Mobil-1 or Amsoil) provides the best protection from rust.
After I clean my gun and apply oil, I tend to wipe away as much visible oil as I can to prevent particles (dirt, metal shavings, etc.) from collecting and causing the gun to malfunction. I felt comfortable doing this with the gun oil I was using, but only because the manufacturer said that this was OK. I assume that it's also OK to do this with Redline, but thought I'd ask the experts.
