OK as a DIYer I continually strugle with rusty bolts & nuts. I need recommendations for a good garage type tourch. Peferably a hand held, small tank one. I'm no pro at welding, just some thing to cut down on time.
Are you wanting a cutting torch or just a propane torch? If you need a cutting torch( oxy-acc) then Victor is one of the best. That's what I have. But you don't need a Victor. A HF torch will serve you well.
most touches use rubber "o" rings to seal the oxygen. if it gets torn they will back fire. its a good idea to have spares in stock all the time. if it back fires and burns in the tube close the oxygen first then the acetylene. then let it cool off be fore restarting it.
Have seen HF torches blow up at the cutting head. They do cut well and heat nicely when working but after seeing one blow up at the head have always been too scared to use
I like Smith torches the best.
A seperate ac/ox tank works the best.
