Quote:
Tigrpal,
Quote:
"Max load 1598 lbs. @ max. inflation 35 psi"
Are you sure about the second "max"? The way it reads doesn't make sense. A tire's load carrying capacity occurs at some pressure - not a some maximum pressure.
Quote:
.... So if I load up the truck I don't dare increase the pressure because I'll be over the max. Neither do I want to have less than the recommended 35 psi. for fear of over heating or not getting the most mpg from these tires. I just don't seem to have any room for error. ...
I think you are misinterpretting the pressure thing.
First, there are circumstances where passenger car tires can be inflated to 44 psi even though the sidewall say 35 psi max. (which I don't think it does!)
Second, the vehicle manufacturer specified one inflation pressure - not different pressures for different loading conditions. That means the pressure listed is adequate up to the GVW (Gross Vehicle Weight). So, according to the vehicle manufacturer, you don't need to add pressure when you load the truck.
So I think you have room for error.
