A little update to this. I purchased the Liquivac and went to change the oil in my Explorer about an hour ago. I played with it a little yesterday just to make sure I knew how to use it and read through the instructions (reading material for the pot). So I went outside, pulled the dipstick and marked my tubing with a pen - as suggested by the instructions. Eagerly jumping into action, I slid the tubing in the dipstick and hit a solid spot about 4 inches before my line that I marked. I tried to push some more, but no dice. So I pulled the tubing out and checked to make sure I didn't measure the opposite end of it, but that wasn't the case. So I proceeded to try again.... same result. I figured I would try to see if I could suck something out. Again, no dice. I think the tubing (smaller diameter one) may be took thick to make its way down to the oil pan. Has anyone run into this? Maybe you have a solution?
