Originally Posted By: DAMO
If you read the original question, it was asking what would the consequences in a mechanical sense be of that issue n ot your "opinion" of the subject. Didn't need you to put your 5c worth in on the obvious. After fatigue and being physically sick it was a mistake but thank you for your straight forwardness. Not needed nor helpful but thanks anyway...
Calm down DAMO.
First, you posted in another off topic Forum and then posted here.
Secondly, it was not clear that this was a totally hypothetical question to the readership here.
As a suggestion, one could simply state, "Hypothetically, what would happen if an aviation hydraulic fluid of MIL " " was put into a turboshaft jet engine such as a... instead of a jet turbine lubricant such as MIL " "..."
No one is being a jerk here IMHO. We're simply giving information to avoid a costly and deadly mistake.
If the containers are clearly marked with each type of MIL STD fluid, there should be no confusion, even if they are located in the same area.
