Originally Posted By: Jaymus
LS1's are fast, like I mentioned earlier, my mom has a 2000 Trans AM WS.6 6-speed.
But it has been a huge POS.
And I am an American car person. Probably will own nothing but American cars for the rest of my life. Have owned all American cars except when I got a 3000GT VR4 and Stealth R/T Twin Turbo and went through a turbo phase.
For some reason, my experience with GM has always let me down. Always. And I just mean reliability. Performance-wise, they usually have the upper hand on everything out of the showroom floor... don't get me wrong... but I think they had a long phase of [censored] (80's-early 2000's). Every company has a vehicle flaw, maybe a particular engine or transmission you could stray away from... but GM put that blasted 700R4/4L60E in [censored] near everything, and also spread those 3.1 and 3.4 engines around like the plague.
I've been a Ford man since I worked in a garage for 5 years. Either way, I prefer American V8 power. Hope to always have a V8 so I can go out and just feel that good old torque.
Mine has been great as far as reliability/dependability goes.
Dunno, but maybe because I have the most basic/simplest of LS1 f bodies, there is just that much
less to go wrong??
The only non-'wear and tear' item to puke out on me (that was not MY fault from modding/changing something), that
might be considered GM's fault was the stock water pump at ~80K miles. But even this may have been my fault since I put an (ASP)underdrive crank pulley on at ~4K miles, and due to there not being an exact size serpentine belt available for this setup, I had to use one which was a little too tight against the tensioner. This added tension
may have cooked the stock pump's bearings prematurely.
