So I just picked up a used boat and trailer, with unknown brand and type of grease in the bearings. I'm going to totally clean them out and start fresh. I want a grease which is readily available, so no boutique stuff that I have to buy out of some guy's trunk. Commonly available in my area are:
Lubrimatic "Marine Corrosion Control and Trailer Wheel Bearing Grease"
Base: Calcium Sulfonate Complex
Dropping Point: 550º F
Color: Dark Blue-Green
CRC Sta-Lube "Multi-Purpose Boat Trailer and Marine Equipment"
Base: Aluminum Complex
Dropping Point: 450º F
Color: Milky / light blue. Some oil is separating out from the grease.
Also, the tube has an ingredient list. Strangely, it lists Calcium sulfonate as an ingredient, as well as aluminum fatty-acid omega3 tofu complex.
This is a large tandem axle trailer, weighs in around 6500 lbs with the boat on it. It has drum brakes, and they do get a little warm. I use it in salt water, so corrosion control and water resistance are the most important features to me.
Any opinions on which one would be a better choice?
Thanks,
Dan
Thanks,
Dan
