The simplest setup, imo, is to go with a single bypass (BMK21) or Dual-Guard (BMK22) and use a Permacool sandwich to plumb it up. You can get a kit to relocate the full flow with the other combo setups, but this allows potential for a much higher bypass flow rate as the oil warms. Depending on how your mounting works out, 2 EaBp90's may be easier ..or one EaBp 110 may be the way to go. You still get to put a EaO right where it is now.
