Im wondering about the normal Coolant Temperature ?
My coolant temperature is between 89 - 105 Celsius..
or if someone likes Fahrenheit 192 - 221 Fahrenheit
i take my readings using ScanGauge II
My system was flushed couple months agoo... around 30K Km.
Cars with electric fans usually will run up to ~210F or so before the PCM turns them on. Below that it all depends on air flow through the radiator. T-stats are for setting the minimum temperature. Radiator efficiency and the fan turn on settings determine the upper temp.
