I have reading on this site for a while now and I just want to comment on automotive oil filters. First off...its seems to be a little too critical on technical specs of these filter element when most automotive filters down to 20-25 micron. Think about this for a second.... most of your bearing clearances are in the range of 6-12 micron range, so your not filtering the contaminents in that range anyways. If you really want your oil to be clean, I would recommend an external kidney loop system added to your engine, filtering at a slow rate (the less the better) with a 3-5 micron absolute filter.
