Code:
MAKE/MODEL: Honda Civic 1.7L (D17A2)
FUEL TYPE: Unleaded 87 Octane
ADDITIONAL INFO:
OIL TYPE & GRADE: Toyota SN 0W-20
OIL USE INTERVAL: 8,320 miles
Comments:
Thanks for the notes. Most of the wear metals are looking good here, and aluminum actually
improved, but lead increased quite a bit. That shows bearing wear and a jump like this certainly gets our
attention. We're not calling a problem yet, but it's something to watch. Maybe a harmless particle streak is to
blame. Keep an eye on your oil pressure just to be safe. No fuel or coolant showed up and the oil and air
filters kept insolubles and silicon low. The TBN was 2.4 showing plenty of active additive left, but try just
6,000 miles on the next oil to monitor lead.
Sample Date: 09/15/12 Makeup Oil: 0
05 CIVIC
Unit/Loc Avgs. Univ. Avgs.
Mi/Hr on Oil: 8320 6140 4980
Mi/Hr on Unit: 64,525 53,062 46,924
Sample Date: 9/15/12 1/15/12 9/14/11
Makeup oil added: 0 qts. 0 qts. 0 qts.
Aluminum 4 5 7 3 3
Chromium 1 1 1 1 0
Iron 9 10 13 8 8
Copper 7 5 5 4 4
Lead 42! 18 7 5 5
Tin 6 3 2 0 1
Molybdenum 108 129 151 128 84
Nickel 0 0 1 0 0
Manganese 0 1 1 1 0
Silver 0 0 0 0 0
Titanium 1 0 0 0 1
Potassium 0 0 0 0 2
Boron 16 14 10 15 39
Silicon 16 17 19 16 11
Sodium 8 13 10 20 40
Calcium 2585 2517 2524 2442 2180
Magnesium 24 919 1463 1271 90
Phosphorus 820 866 930 847 686
Zinc 906 921 993 863 820
Barium 0 0 0 0 0
Values Should Be
susV@210*F 53.3 46-57 51.8 51.9
cStV@100*C 8.26 6-9.7 7.82 7.84
Flashpoint F 470 >385 395 410
Fuel%
Antifreeze % 0.0 0.0 0.0 0.0
Water % 0.0
Insols % 0.3
TBN 2.4 >1.0 --- 8.1
Blackstone did the analysis. What's up with the lead? Also, why does the thinnest OTC oil on the market look so thick? The previous 2 samples shown are RP 5W-20 which is a much thicker oil.
Is the iron a problem and is this oil showing oxidative thickening at 8320 miles? I thought this was an easy 10k mile oil in this engine. Very confused. Is there a chance that Blackstone mixed up my sample?
ADDITIONAL INFO:
Comments:
05 CIVIC
Aluminum 4 5 7 3 3
Chromium 1 1 1 1 0
Iron 9 10 13 8 8
Copper 7 5 5 4 4
Lead 42! 18 7 5 5
Tin 6 3 2 0 1
Nickel 0 0 1 0 0
Manganese 0 1 1 1 0
Silver 0 0 0 0 0
Titanium 1 0 0 0 1
Potassium 0 0 0 0 2
Barium 0 0 0 0 0
Values Should Be
Fuel%
Water % 0.0
Insols % 0.3
