Factory fill- not sure what Chrysler puts in, but probably 5W-30, which is what Blackstone called it- on a new 5.7L Dodge 1500 4x4, purchased off the lot 1/05. Sample was taken 2/2/05 at first oil change and stored in a glass jar until 2/12/05 when my first kit came.
Element Sample Reading Univ. Avg.
Aluminum----------4---------4
Chromium----------2---------1
Iron--------------41--------23
Copper------------130-------45--Highlighted
Lead--------------0---------5
Tin---------------0---------2
Molybdenum--------140-------28
Nickel------------1---------1
Manganese---------4---------1
Silver------------0---------0
Titanium----------0---------0
Potassium---------5---------1
Boron-------------51--------47
Silicon-----------7---------13
Calcium-----------1284------2045
Magnesium---------7---------237
Phosphorus--------620-------796
Zinc--------------776-------979
Barium------------0---------0
Property Tested Value "Should Be" Value
SUS Visc.------49-------------54-61--Highlighted
Flashpoint-----385------------>365
Fuel----------- Antifreeze-----0--------------0
Water---------- Insolubles-----0.4------------
Blackstone Sez:
"We've highlighted copper in your sample, but except for this one quite high wear-in metal, your engine is really doing well at the first oil change. High wear and silicon are both common finds in oil samples from new engines. The wear is high due to break-in of new parts, while silicon is from sealers and sand-casted parts. Your silicon was exceptionally low. Universal averages show typical wear metals for an oil from this type engine after 4,735 miles use. We expect your engine will look in a couple of samples. Try 3,000 miles for the 2nd sample."
Being a first sample on an unknown factory fill, there probably isn't a lot of info we can gain from this analysis, but I thought I'd throw it out there anyhow. At this oil change, I went with Schaeffer's Supreme 7000 5W-30 and a PureOne filter. I plan to change it out after 2,000 miles and then go to 3,000 mile intervals on Schaeffer's 5W-30 in cold weather and 10W-30 when it's warm with CarQuest/Wix filters. I know a lot of you will probably tell me that I'm crazy for changing Schaeffer's that often, but the manufacturer calls for it, plus I just enjoy changing my oil. So anyhow, make of this what you will. I plan to do analysis at every oil change to maintain a good record of my truck's internal condition, so we'll see how it looks in a couple thousand miles.
Blackstone Sez:
