1988 Cadillac Brougham 307 V8 4bbl/ auto
Rotella T5 10w-30 + Bosch Premium filter
"It's another good report for this Olds 307 V-8. In fact, this is the best of the three we've seen so far. Wear metals dropped again after a longer oil run and there was nothing in this sample that would point to a mechanical problem in the works. It will be interesting to see if the change in your commute has any effect on wear. It might bring metals up a little, or maybe not. 24 miles in a day is still a quite a bit of use. Insoluble were fine at 0.3%, showing good oil filtration. The viscosity was on target for a 10W/30. Try going up to 5,500 miles next time."
Miles on oil- 4,356
Miles on car- 119,864
Sample date- 07/20/2013
Qts added- 4
Element- current- prev1- prev2
Aluminum- 18 19 23
Chromium- 2 3 5
Iron- 56 76 140
Copper- 3 3 6
Lead- 10 12 28
Tin- 0 0 1
Molybdenum-72 93 11
Nickel- 1 1 0
Manganese- 1 1 2
Silver- 0 0 0
Titanium- 1 3 30
Potassium- 6 2 4
Boron- 39 45 8
Silicon- 12 10 10
Sodium- 38 67 298
Calcium- 2976 2681 2306
Magnesium- 15 16 19
Phosphorus-1087 885 854
Zinc- 1310 1021 1081
Barium- 0 0 0
SUS Viscosity@210 F- 60.3 59.5 66.2
CST Viscosity@100 C- 10.29 10.08 11.93
Flashpoint in F- 400 395 400
Fuel%- Antifreeze%- 0 0 0
Water%- 0 0 0
Insolubles%- 0.3 0.5 0.5
Miles on oil- 4,356
Qts added- 4
Aluminum- 18 19 23
Chromium- 2 3 5
Iron- 56 76 140
Copper- 3 3 6
Lead- 10 12 28
Tin- 0 0 1
Molybdenum-72 93 11
Nickel- 1 1 0
Manganese- 1 1 2
Silver- 0 0 0
Titanium- 1 3 30
Potassium- 6 2 4
Boron- 39 45 8
Silicon- 12 10 10
Sodium- 38 67 298
Magnesium- 15 16 19
Barium- 0 0 0
Water%- 0 0 0
