Fords have had adaptive charging or smart charging or whatever you want to call it since like the early 2000s? As far as I understand it there is a voltage regulator in the alternator but it's controlled by the ECM/PCM... I'm sure pretty much any modern vehicle including your Honda has it. So basically you can't reliably test it with the parts store testers that connect to the battery terminals.
As for the tester damaging the alternator, I doubt it. Though a bad battery can definitely kill an alternator fairly quickly.
Group 51 and other compact battery sizes are usually far less reliable than physically larger batteries. Size 35 batteries fit in most Accords with 51R batteries. In CRVs as well but you have to ditch the plastic spacer tray thing on some years... just did one this morning.
Pretty sure the little battery in my Escape isn't long for this world since I have an upgraded audio system and I often listen for a long time without the vehicle running. But my nice group size 65 AGM battery I had in my Crown Vic couldn't fit so unfortunately that buyer got a brand new $190 battery that still cost me like $100 on a car I sold for like $1700... I might be able to fit a 47 or 48 or 35 when it's time to put a battery in my Escape though!
